87 GN- no idle
acg72
Not sure if anyone can assist me but let me give you my scenario. I installed A te44 turbo and blue tops with matching chip that from turbo tweak several months back. I did the steps to reset the ecm. The car ran good with a smooth idle. However my inspection was out so I only drove it for about 5 minutes through the neighborhood. I have been starting the car every few days to keep battery charged. I noticed at first the idle started to get a little rough and now it will not idle or stay running unless the accelerator is pushed and misses real bad when trying to drive it. Is this possibly from not driving it long enough after installing new chip. Will taking out chip and reinstalling it help or fix problem? Any suggestions.....Thanks
If the car ran good for a period of time with the new parts, then it's doubtful the chip is causing any issues.
Your description of the problems however, does sound like it's very possible the MAF has gone bad or is on it's way out.
X2, check maf sensor
