Kid Turbine
- Jul 17, 2007
87 Turbo T (Fast, very fast)
4.1 non stage block 257 c.i. motor (torqueplate bored and linehoned)
8.7:1 comp.
Jack Cotton CPT-61 Turbo
Front mounted intercooler
Custom 9.5" 2800 Turbo convertor
Sealed power Hyper pistons (4.005")
Reconditioned 2 dot rods
Reconditioned 10/10 Turbo crank
Upgraded GN Heads with LT1 springs
Felpro 1000 head gaskets
MSD 50lb injectors
Comp Cams 212/212 camshaft and lifters
Phelum Power plate
Turbo 350 trans (Fresh)
B&M Rachet shifter
MSD Combo tach and boost gauge
3.42 gears with non posi but have one that needs rebuilding
stock ecm with Turbo Tweak chip for build
Car is running!!!!!!!!!
Not installed parts
MSD DIS-4 with interface
Accel DFI6 ecm (have tune to install for motor)
will run mafless with Accel ecm
I have a posi unit but it is a 30 spline and would need to upgrade to moser 30 spline axles!!!
car will need paint maybe down the road
window felt both doors
seats recovered (not bad)
and wind shield replaced
car comes with extra stock motor will need a rebuild!
it is engine build that would go 6.90's easily with about 20-25 lbs of boost.
no rust on the car and not even under the car!!!!!!
Let me know what you got!!!!!!!!!!
Trade for LS/ OL 10.5 roller (25.2 or 25.5)
Toter vehicle or 28ft enclosed loaded trailer
cash
8.7:1 comp.
MSD 50lb injectors
Phelum Power plate
B&M Rachet shifter
Not installed parts
cash
