87 we4, .020 block, dual row timing chain, ported heads intake dog hose and throttle body, rjc power plate, comp 210/215 cam, morel rollers, harland sharp roller rockers. Pac beehive springs, new front cover/ oil pump, new water pump, ptc 10" 3200 nl stall, shift kit, billet servo, power logger, scan master, turbo tweak 6.1, lc1 wideband, lt1 mad t translator, racetronix 340lph pump and sender, race tronix hotwire, 80# injectors, -6 return fuel line, accufab regulator, precision 6266 billet turbo, 25 psi boost, Alky control single nozzle, case v4 slic, 3"thdp, cutout, 3" pypes race pro, 3 row aluminum race radiator, b&m trans cooler, AC/heat delete, radio/hvac delete, south side machine lift arms, koni adjustable shocks, eibach pro kit springs, rear seat x brace, 275/50 bfg drag radials, aluminum bumper supports, driveshaft loop,atr rear sway bar, auto meter tach boost water temp oil pressure gsuges. Caspers knock gauge, that covers most of everything. Haven't had it to the track but I'm guessing high 10 to low 11.
Have over 18 k invested it it. Has some rust in the 1/4 panels but I have complete 1/4s to go with it. Has rust in drivers side front floor pan only. I have a floor pan to replace the rust.Rest of the floors are solid. Rockers have no rust at all. Bumper fillers are cracked up and fronts are removed. Interior is all out but seats and dash. I have it all just took it out to fix floor pan and haven't gotten around to it. Dash doesn't have any cracks. Front seats need to be recovered, rears are nice. Asking $13000 obo. Have $10k in drive train alone all parts have 1000 miles or less. Turbo,Alky, injectors all have less than 200 miles on them..... pics will be added for some reason its not letting me add them right noe
