87' White T-type : W02 & Astro roof
SVORay
Well I'm looking into buying a Typhoon but the wife said I can't have more than one toy. So I'm selling off the T-type. I'll try and be as up front as I possibaly can be about the car. Also, please don't ask for pictures untill after you boiught the car...ok that was a bad joke lol. Anyhow, I'll post up more picture if requested.
1987 T-type Regal White w/burg interrior and astro roof plus digital gauge cluster. It's also got the W02 package which basicaly means a black out package. No, the bumbers being black is not part of the W02 package. All T-types came stock with chrome bumper...there seems to be a growing group of white T-type guys installing black bumbers. Anyways, I can get a set of chrome bumpers if you don't like the black bumpers. It's also got a set of some kinda aftermarket almuinum wheels...skinnys up front and something like 15 - 8's out back with MT DR's.
The car has ran 7.60's in the 1/8 in Denton Texas using the old Turbo at 18psi. It's got a TE44 turbo with about 2000 miles on it. The motor was rebuilt about 10,000 miles ago and the heads was p&p..plus a 208/208 cam installed. Currently the motor has a safe street chip and running 15psi.
MODS: TE44, Turbotweak chips ( street and race), K&N, rear air bags, MT DR's, 42lb injectors. FPR, unknown fuel pump upgrade, hotwire kit, scanmaster, Bost control, cut out, and a few other things.
The bad: The bumper fillers are shot. I have the fronts but they need painting and installed. I also got a new front air damn to go with it since the old one is scratched up. The drivers seat has a small burn hole but most of the interrior after that is really decent. I'm pretty sure the gear box may need rebuilt but not a 100% sure. It's got a Stage rite trans brake and that maybe the corprate. It will not go into first gear period...so it's slow to take off. Once It's around 15mph everything shifts fine. I was going to rebuilt the gear box either way.
The car also devaloped a short and is currently being fixed. While it's in the shop I having them install new battery cables and window motors...all of which I bought from Kirbans. Thats about 300.00 bux in parts alone. I believe the short is an A/C related issue that was caused by water getting in the compressor some how while I had a quick lube place flush the radiator. Anyhow, with any luck the A/C will be up and runnig again.
I have a small collection of parts ordered from Kirbans and other places I would be welling to let go with the car if the price is met. This includes, the water juges for under the hood. A chrome turbo heat shield w/ Power 6 logo(260.00). Vaccum brake booster w/MC.( the stock brakes work great but I don't trust the Powermaster system and thus was going to convert it to vaccum). New radiator cap and over flow cap. An RJC power plate...this evens out the air flow in the intakes and will allow up to 17psi of boost on pump gas and no Alky in some cases. These are all new parts still in the box. I also got some used parts like the torque rods for the trunk so you don't have to use a stick and a seat belt retractor for the drivers side thats broke.
My goal was to make the car clean 8)
My asking price is 7500.00 obo.
I'll post a picture shortly and will email more if requested.
Ray
Location, Midland Texas. I'm pretty sure It is a born and raised Texas car.
Here is some more pictures I uploaded just now. Also, I bought a set of those plates that goes around the shifter etc. They make it look like New. The ash tray pice has the Painted Power six logo and the thin little pice below the ash tray is personallized. That thin pice shouldn't cost anything at all to replace. IO bought it from a vender out here and will post a link later on to the site.
the bad...
I actually did this part my self :redface: Anyhow, I got a new air damn and bumper filler for it. The only thing that needs done in the support poped out and the filler painted. The other side has a new filler painted/installed but the paint color is off just a hair.
I got a mirror off another T-type w/remote cable the replace the drivers side mirror. It just needs to be painted to match.
The rear fillers are shot as well...near the LIC plate and the lower courner area.
Just wanted to let people know I'm not interrested in reducing the price based on wether or not the gear box is worse now than when I got it. The car had a 2-3 flare issue and was missing first gear when I bought it. So nothing changes the fact it needed rebuilt then and it needs rebuilt now. I would actually say the car drives better now than when I got it...the 2-3 shift is almost non noticable. You don't have to let out of the throttle in order for it to shift gears. Anyhow, here is a few more pictures of stuff I bought to improve the car....
If you look closely at this first picture, you will see it's missing the trunk rods that hold the truck open..thus the stick. You will also notice the trunk divider ( carpet between trunk and back seat) looks like a rat got hold of it. Plus there is no "X" braces etc.
here is a picture of the trunk rods, "X" brace, and trunk divider...everything new except trunk rods. I would have to check my invoce but I think the "X" brace is 80.00 bux and 30.00 for the divider.
Power plate , seat belt hangers, and under the hood braces.
Stock battery hold down and bumper filler to replace the passenger side thats pretty shot.
new air dams...the old ones have some white over spray and the passenger side got scrapted petty good. Anyhow, that should have the front end looking sharp for sure.
The brakes work fine but I hate the Power master. I was going to go the Hydro route but at the last minute swaped over to vaccum. The boost and M/C are BRAND new, not junk yard parts. They run around 500.00 through Kirban and I have the envoice for it.
280GNZ,
Thie GN with the weld scorpions is my old 87GN.. Man I regret the day I ever sold that car..
Jerry's Donor Car
If you didn't know, it was owned by Byron Bennett (Bennett Racing - Ford guys) before me..
Donor Car!!!
Don't worry, Warren?
Look close at the page and you can tell they are two different GN's. Your car has not changed any (other than Bumper fillers) since I bought it from Brad. Its only been driven a handful of miles. It's too nice to enjoy. (Can't leave it parked or scared an idiot's gonna hit me driving it) By the way I need your email. So shoot me a email to Bolton@1Badz.com
Thanks Jerry
Is there anyways you two guys can take this to PM or create a thread in Turbo Lounge? This thread is for selling the above mentioned car.
Ray
chit chat keeps it fresh... to a point :D
Yes sir, and I really don't mind that at all. I'm simply asking that people do not post information or links about another car on my for sale thread is all. If they want to help someone out, simply PM them or make a thread of their own. I will in turn do the same for anyone else. It's simply a conflict of interrest.
Ray
Roy, Sorry. But, I am the ONLY one that has asked about your car on this post. As roadrunner88 said, we are saving you from having to spell Bump.
If you have noticed I asked 1ARUNEM to email me. That should of been a sign that the next communication between us would be done from here and from now on done through email.
Best of luck selling your car. I'm no longer interested.
thanks Jerry
thanks Jerry
I'm sorry you feel about it that way but I'm sure you will find something else out there that fits you.
Thanks for looking
Ray
I've had a few people pm/emailing about the quaters and door jams...plus option tag. So I went and took a few pictures...
both door strikers have small stress cracks. I was going to order some plates from Kirbans to help with this problem but I never got around to it.
the quaters have rubber sprayed on them but there is no rust.
I replaced this whole pice around the shifter counsol...I added the T-type logo and a personal messg just under it. You should be able to replace it for next to nothing...depending on if you leave it blank or add something like I did.
