wants a tr
home of the money sucker
- Jul 18, 2001
i just installed my kit last nite. going to the track tonite. at the track i run avgas and can run 20 lbs of boost. so for alky and avgas should i set the turn on point at about 18 ? what about pump speed? if its too high will it slow me down? i dont want to just overspray the alky and waste it. would 18 psi turn on and about 6-7 for pump speed be pretty good? this is using a reds 100 chip. and my sig. with stock turbo/ic/heads. TIA
