a question for razor..
jamier
just a question for razor
I'm currently running 25lbs boost with 94 octane gas and alky, I started getting about .3 knock at the top end of the track. just started suddenly. I'm still running the stock timing with erics street alky chip, I want to advance my 1-2 gear timing but won't until I'm sure I wont blow something up .I'm running erics suggested 43 lbs fuel pressure. and o2 are in teh 750 range with a low of 740 at wot last weekend. Should I bump up the fuel pressure, then back off the alky since I have the blue knob all the way? Or should I do something else any suggestions.
Too lean. I answer on the other thread. You need to be at 780-800 for O2's then work on leaning it out to se IF it makes more power. Not start lean then work your way up.
Place the chip in program mode and bump the WOT fuel setting ++++++++ and start rich..
HTH
Is a lube necessary for alky??
should I be using a pump lube in my alky? Also to razor thanks for the advice on my fuel pressure....will let you know how it goes.
No lube needed.. wont help anything. At best its adding oil into your motor.. which you have plenty off :)
Add fuel by placing chip into program mode.. in doubt.. contact Eric for clarification.
HTH
