I have a spring 1985 edition of "Muscle Cars" magazine ( Schneider performance series) that has an article and a few pictures ( one that show a reversed 84-85 intake), unfortunately most of the 2 page spread shows an 85 t top regal with concept add on body work, and two small engine pictures, one is from the 85 brocure showing a stock 85 engine, the other about 2"X4" showing the McLaren experiment engine. If I can will post it in the future, though can't promise, anyway I'll describe what there is to see; the manifold is completely covered so it is not at all visible but is an 84-85 mounted in reverse. The coil pack sits right on top the plenum dead center, and mounted to a metal plate that is just slightly larger in footprint of the coil pack. The thermostat housing is not visible but is towards the firewall (buried) and hard plumbed from there towards the master cylinder close to the firewall then disappears from the picture (sure it 's going to the radiator). This plumbing has a tee in it which is located behind driver side valve cover, sort of jury rigged with a radiator cap and overflow tube probably to burp the coolant at this point. The turbo is mounted similar to the 86-87 up front, can't see any detail of the brackets though, or if the ac compressor is still there, the throttle body is still attached to the turbo as 84-5 ( inlet side of turbo) and is located behind radiator shroud and centered, the inlet/air cleaner set up is not visible. The intercooler they used is not visible though it is an Air research according to the article, the output tube of the intercooler, probably aluminum is made up of at least 3 pieces welded together ( looks pretty good) runs up from behind the fan shroud similar to 86-7 with a smooth radius, over the throttle body and into the intake with a very mild bend. It sure looks like it is going into the stock turbo port of an 84-5 intake (sure not an 86). The alternator is on the driver side and looks to have the serpantine belt style, no detail shown for brackets. Only other thing I can see is the throttle body linkage comes from firewall, runs over the alternator, and ends at TB behind fan shroud in center, oh and there is a fabricated shield over the turbo similar to 86-7. That is the best I can do for now, if I can send the picture I will. This issue of Muscle Cars magazine had a lot of the Buick performance history in it, GS's, Rivieras, and GN's, one article I liked was the twin turbo 83 Riviera pace car, cool!
