Hunter Dog
- Aug 1, 2015
Wondering best way to fix a cold, clear water leak above the passenger's feet which is coming from below and behind glove box that is running down the black, plastic housing area which has two visible 7mm screws facing toward the rear of the car.
We are seeing condensation from the a/c drain into the two small door flaps as well as out the small hole under the heater core as I believe should be the case. However, we are also having some cold water (less than what is coming out underneath the car) dripping on my wife's feet when she is riding in the car, or on mine if she is hammering it down the highway.
When I removed the two screws I was able by hand to slightly spread out the black, plastic area where water is not standing in this area but running along it and eventually down to the floor. I am wondering if I can seal this area up (if so, best product to use?) and if so would that solve the problem or is this just a bandaid that is not addressing the real root cause of the leak?
Thank you for your time.
