Ac delete help
gentek10
Im installing an ac delete pully and bracket. I noticed the pully is smaller then the original on the compressor.. Can u use the original alternator bracket and what size belt do I need?
Yes you can use the alt bracket along with all the bolts. As for the belt your gonna need a 30. Regular belts have 40 on the end. So the belt is smaller than stock
