Accumulator ball,gray brake switch,test pipe
2QWIK4U
Swapped car over to vacuum a while back,the pump motor went bad on the powermaster again so I swapped it over.As far as I know the accumulator is good(only used it about 5 months) and the switch is good I know cause I replaced it thinking it was the problem instead of the motor.
Accumulator $90
Switch $100
Test pipe $60,this is not a dump,think I bought it from Postons.I switched to a THDP set up.Prices do not include shipping.
Accumulator $90
Switch $100
Sent you a PM
