Adjustable uppers a must when lowered?
CopGn
I dropped my car around 2". Are the adjustable upper control arms a must now to set the rear angle?
I don't know any other way to change pinion angle without drilling new holes. If you are not getting a vibration @ steady 55-65 cruise in o/d, then I would not bother.
My concern is am I losing traction by dropping the rear end and changing the pinion angle. Anyone else?:confused:
Lower??
Lowering the car just helps a little in re- locating the already incorrect instant center location, to a bit more favorable point.
FWIW, The pinion angle is not a major tuning tool. It's something that helps reduce driveline bind, thus freeing up some HP to use where it's supposed to be.
There have been a bazzilion posts in ALOT of threads on this. I'd suggest a archive search, as it should give you some good info... and some "not so good"..:eek: :eek:
