To follow up what was already posted, since you are running an aftermarket cam trial and error is what is called for. Advancing the cam will shift the powerband to a lower rpm, retarding it shifts it higher. I would not try advancing or retarding a 220/220 billet roller at first. The roller already maximizes the profile by manipulating ramp speed using roller lifters vs. flat tappet. The result is the idle and low end is better with the roller than a flat tappet. If after installing straight up, you feel a need for a better low end or a better top end, then go in 2 degree increments until you are either satisfied or you feel it is having a negative effect. Just be advised that what you add on one end, you take away from the other.
