Aem
my brother in law has one on his trailblazer ss which is supercharged. the kit works well but it is meant for injecting a water and meth mix. he was told that if using straight meth the pump life would be shortened. if wanting to inject straight meth i would use razor's kit.
Has anyone used this kit? I was thinking of giving 1 a try. I can pick one up locally save some time and shipping costs.
AEM - Water / Methanol Injection Kit*
$460 dollars ouch thats alot of money for a kit that is not tailored for our cars. try WWW.ALKYCONTROL.COM well worth the $ and the way your car runs out of the box along with there customer support is all worth the $. if you do choose to go with the aem kit let us know how it works. good luck on your choice.
Thanks for the reply's. The only reason I considered this system was availability and it looks like it should work well its progressive which makes tuning easier most of the progressive kits I have seen in Canada are quite a bit more money. I can get 1 locally and I don't have to deal with freight and duty. The pitfalls of living in the great white north..........
You wont be able to fit that 1 gallon tank on your Buick. By the time you get better hoses, fittings, filter, and a proper tank.. you'll blow way past what we sell our system for.
You also need a 3 bar MAP for that system.
I sell a lot of kits to Canada, there are some simpler shipping options.
HTH
HTH
What would I be looking at for freight on one of your systems to V0R1G0 postal code? Vancouver Island BC
