AFPR Bolts
ALXTTA 1
Hi all,
Just got done swapping on a new turbo and injectors. Had it all back together, ready to fire up, just had to check fuel pressure for any leaks and noticed I had a small leak at the fuel regulator-to-fuel rail connection. Figured I'd tighten up the bolts a touch more..and..SNAP..one of the little bolts breaks. :mad: :( So...anyone know what size those 2 little bolts are that bolt the AFPR to the fuel rail? And what would be the easiest way to get the broken 1/2 of the bolt out??
Thanks.
Whew..nevermind!! Went down to the hardware store and found the right size replacement bolt, 6mmx12mm I think it was. I also got a 6mmx30mm bolt. I got really lucky and was able to use the 30mm long bolt to push the broken end of the old bolt out the other side. :)
