Nov 18, 2007 #1 R RatFink PutTheNeedleOnTheRecord! Joined Nov 7, 2006 Messages 2,034 Is there a chart that shows what your Air Fuel Ratio is in relation to what the scanmaster shows on the 02's?
Nov 23, 2007 #2 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 No. Its all about guessing. The lower the number, the leaner it is.750 is leaner than 800. HTH If you want AFR..get a wide band
Nov 23, 2007 #3 1 1BADDAM Venomous Snake Handler Joined Jul 30, 2001 Messages 714 It's more of a switch than an analog device.
Nov 23, 2007 #4 Q Quiky One Active Member Joined Dec 31, 2005 Messages 8,079 Haha that graph is way off. I typically run .760's-780's and I know I am not running 14.0:1...I would blow if it was that lean. Jason
Nov 23, 2007 #5 S SNOWBIRD New Member Joined Jan 8, 2007 Messages 859 I Tend To Believe The More You Modify Heads And Turbo ,, Cam Shaft The Less Accurate Your ...nb...(oxygen Sensor) Becomes And Thus A Wide Band Is Needed To Properly Tune Your 109....this Is What I Believe....anybody,, Educate Me
Nov 25, 2007 #6 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 The narrow band is also sensitive to temperature. Example if you run lower timing it will raise your EGT and lower your O2 sensor voltage. Not saying you cannot tune with a narrowband, I have personally seen a 109 motor tuned into the mid 9's on a scanmaster and (afs20)narrow band sensor. The wideband when accurrate saves times and parts breakage.
