I purchased a set of mechanical gauges (oil and water temp) from Summit to go into the pod on my floor console. As far as the oil gauge the mechanic had no idea where it would connect. In regards to the temp gauge he was concerned about touching the sensor in the intake manifold saying it looked like it might break trying to take it out to install one for the gauge use. Is any of this true? Should I go to electrical instead. If not where are the proper connection points?
