I believe it is B&M that sells a transmission plug kit that will work on any trans pan.  You drill a 1/2" hole in your trans pan, and put this fitting in the hole and tighten.  It has another small bolt inside the first one that comes out to drain the trans fluid.  Check Summit or Jegs.  Very cheap and works perfectly.
