hi just want to know what pumps were used on the old air research double pumps set up i have a brand new set up that a got years ago and want to know if they are e85 compatable .thanks in advance
The biggest available for stock computer are 85s. Anything bigger will require the installation of peak/hold injector drivers. What turbo heads and cam do you have
te 44 gn1s 8 bolt champions billet roller 206/206 70mm tb powerplate and 70mm gn1 plenum 1.65 t&ds morels lifters gen 2 lc1 innovate and alcy kit every thing is new dont have the motor together yet getting close .
The 85s should get the job done. I think Full Throttle sells them.You won't need the alky kit.
Youl'd also do good to get a Translator Plus,3.5"MAF,and an Extender chip while you're on the phone with Full Throttle.
Yes,but an extender Chip compliments the Gen 2. Actually,they compliment each other. Together,they are a complete package. E85 is available at certain gas stations in certain parts of the country. You'll have to look at your local gas stations.
