Ken,
As the topic header reads, I took the car out of Storage yesterday (Finally some decent weather here)
as soon as I put the cable in it threw the car into ALDL Mode. Now this DID happen before, but as soon
as Turbolink powered-up and I connected, it went back to Normal.
And YES, I did check to make sure NORMAL Mode was commanded in ECM Mode!
And YES, I did try Fresh Batteries!
But as soon as even the cable was pluged-in, Turbolink not even on - BAM high Idle & ALDL Mode - Remove the cable, and its Back to Normal!!! The last time I used the car & Tlink, it worked perfect, although like I said above, I've always seemed to have the problem of Not being able to leave the Cable plugged-in as It would Command ALDL Mode until Tlink was up and running
I can send you the cable, Let me Know
Thanks! & Happy Holidays!!!
Brian
Brian
