I
Iamdreaver
Guest
Some people have told me that if i get a hot air car that i shouldnt even worry about an intercooler. they say to go strait to alky, what do you guys think?
SignUp Now!Originally posted by turbowrenchhead
I put on the smc alky kit and I was able to run 5 more pds of boost on pump gas. I could turn it up more and turn up the boost more but I didn't see much of a differece. It would get bogged down after a certain point. I do like the system and would recommend it. I put in the ford i/c after the alky and the i/c made a much bigger difference then the alky. Just my experciences.
Originally posted by JDEstill
Well, if you ask me, I think that you will see a bigger improvement with an IC than with an alky system. But for the money and the hassle, it's not a clear cut call. Kinda up to the user to decide what he thinks is more cost effective.
I also don't think that you can really max out the existing alky systems. There is some ideal ratio of water/alky to fuel, I can't remember what it is. 1:3 maybe? The alky systems I know of inject a constant amount all the time. So if you have just the right amount at 3000 rpm, you have less than the right amount at 5000 rpm. Get it to where you have the right amount at 5000 rpm, and you have too much at 3000 rpm.
Ideally you'd have an ecm type of thing, controling the water/alky inejction rate vs. air flow, just like the fuel injectors are controlled.
But, to go cheaper, if someone could just figure up a way to scale the injection rate to rpm, I think they would have the better mousetrap, and you'd see a big improvement in alky system performance. The two ways I can think of would be to use either the tach lead under the hood, or to intercept the injector pw signal. Then have that automatically adjust the pump output in some fashion.
I do think that alky on a 20 psi hot air car could drop the temperature by 170F, given the caveats I listed in my post above. I think the limitations of the current systems out there would not let you actually do it though, you'd probably bog the heck out of the engine while trying to get there.
John Estill
