Alky nozzle placement ?
cool 84
Got hotair?
Since I'm getting close to having the POS running I've been wondering where the best place to mount the injection nozzle is. My car is a hotair with a Ford intercooler. Starting from the outlet of the intercooler near the radiator I could put it anywhere from the outlet all the way to the throttlebody which is up against the firewall. I have a good 4' to play with and I have a lot of room for mounting. Is it better to have it back a ways to let it mix and cool the air better or should I inject it near the TB like most of you guys do?
Kind of off topic but does it matter where the BOV is mounted as long as it's on the intercooler outlet side? I kind of wanted it as far upstream of the alky as I could get it. Thanks.
I would mount the nozzle higher than the reservoir and as close to the TB as possible. Keep the BOV torwards the IC.
See when you spray alcohol and slam the TB closed there is alcohol left in the up-pipe. Hence the reason for keeping the nozzle away from the BOV.
HTH
Julio
