All My V6 stuff is up for sale!!!!
TURBOKID
Everything on or in the car and everything under the work bench is for sale. I will have a list soon of the parts and will make new list as I find stuff. I will not sale my stuff for nothing so if you are not serious about racing and going fast don't waste mine and your time please. Not a lot of ? about everything, My stuff is nice and has always been No money spared on my motors. I also have two stock blocks .030 over and 2 stock cranks I think .010 have to check. I am pieceing my stage 2 stuff out. So get in line if you have deep pockets the badest motor is being sold.
919-773-0494
No I dont have a camera right now
Well if you're in n.c., that's put you three hours ahead of me and I won't call that late. I am always looking for quality stage parts, I'll wait for your list.:)
Richie, I replied in S2 section regarding headers, interested n other parts. Give me a call or shoot me an email
--moldex crank 3.625 with JW flywheel and BHJ damper .010 over on mains.--- 1900.
--Stage 2 alum. heads with Jessel rockers and extra rockers and vavles, and a lot of vavle springs. 1 1/2 years old, tit. and inconel valves-- 5000.
-- liquid intercooler 3inch inlet and 4 inch out let with 4 water holes-- 1300.
-- headers with cross over and these are still good they have been fixed a couple of times look a little ruff but just took them off of the car .Locates turbo behind right head lights. 4 bolt flange includes HKS racegate # 1405. and 4 extra stage 2 header flanges, they also have egt holes for clamp still fittings I do have those I can sell also-- 1500.
have to go to work now more to come
Add this to the heads Intake with 160's, rails, elbow, T/ Body 90mm, and all sensors match to heads. All for $5800.
---MSD 7Al-2 Part #7226 have 2 of them--$300. each
---MSD Dist. set up for trigger. comes with spare cap, and rotor--Part #8551--$200.
---MSD Crank Trigger wheel and pick up Part#8630-$175.
---Weldon fuel pump Part#2025 and regulator #2040-$650.
---SX Fuel pump Part#18201-$200.
---Stock Block 109 .030 over $200.
---Stock Block 109 .030 with steel caps $300
--- Stock cranks I have 2 .010 on both $300. each
---2 Stock intercoolers Offer?
---4 or 5 stock timing covers Offer?
---Stage 2 heads and intake comes with everything you need to bolt on and run: Jesel rockers on heads plus 10 extra, Valve covers, 3 extra valves tit. intake and or Inconel ex.valves, 2 sets of valve springs, Push rods, and Isky roller lifters. Intake has TPS, IAC, IAS,CTS,4 vacuum ports and temp gauge hole, 160lb injectors, fuel rails,elbow,90mm T-Body, about 2 or 3 sets of plugs also. Head are only a year and half old. Very nice RACE port work done.--$5800.
--- Intercooler is a Liquid to Air that can fit behind stock Rad. It has 3inch inlet and 4 inch out with 4 water holes Air temp was always around 60degs with this on my combo sold new for $1823.
asking $1300.
all for now
I have pics now
---GT 47-88 turbo very bad ass unit $1500.
---MSD DIS4 unit my old units I have two left $200
---set of NEW stock OE turbo pistons, also comes with stock rods and a set of used stock pistons $150.
--- 2 sets of .030 stock pistons one set are TRW's and the other are a nice ROSS piston with a set of rods. Ross's have a heart shape top.$150.
---Moldex 3.625 crank on center motor .010 over on the mains, comes with sfi BHJ damper and JW flex plate $1900.
--- Complete MSD ingation system for stage two 7AL2 box,msd dist,cap,rotor,crank trigger,extra cap,rotorand ultar 40 wires$675.
Day 919-274-4336
night 919-773-0494
How much action have the pistons seen? Are they all in good shape?
Are they still for sale?
The TRW pistons are in good shape not sure how many miles. If I were you and I'm not I would use the ross pistons.
---6.5 inch Oliver rods I have 11 of them sell all for $1450 they are ready to go. On center
