Mar 1, 2012 #1 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 will alky raise O2#, or just adding more fuel?
Mar 1, 2012 #2 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,771 unless you run o2 correcting engine management...it will go richer (higher 02 mV, lower A/F reading) as the alky is introduced ,
Mar 1, 2012 #3 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 pacecarta said: unless you run o2 correcting engine management...it will go richer (higher 02 mV, lower A/F reading) as the alky is introduced , Click to expand... thanks, thought so, alky is fuel too.
Mar 2, 2012 #4 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 SIXBANGR said: thanks, thought so, alky is fuel too. Click to expand... yes, But you want to run the bare minimum you can get away with. That way its not as dependant on the alky. ] Use fuel for O2.. use alky for knock. And yes the alky will richen it up.
Mar 2, 2012 #5 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 Razor said: yes, But you want to run the bare minimum you can get away with. That way its not as dependant on the alky. ] Use fuel for O2.. use alky for knock. And yes the alky will richen it up. Click to expand... I added about 15% more fuel and have the alky down to 5 1/2, no knock now at 24lbs.
