Finally reached my goal for the season. I think there's more in it because I only got to run once and didn't uncap the exhaust. Only launched at 4 lbs. 'cause it was the first run w/ the transbrake. The track told me I couldn't run anymore because I don't have a rollcage. So that will be a good winter project. Only had the car a year. The people I bought it from would cringe if they knew what i've done to it! Bone stock, cloth festival car #33 with 8000 miles on it.:redface: Here's the breakdown......:biggrin: :biggrin: :biggrin:
Details of the run:
60' 1.655
330' 4.535
1/8 6.926
MPH 102.59
1000' 9.002
1/4 10.768
MPH 127.57
Screen Name or Car Number Here: ttafan
EMPTY WEIGHT: 3650
BLOCK: stock
HEADS: Stock Champion ported
CAM: Comp Cams
TRANSMISSION: 200r4 w/ Stageright
TORQUE CONVERTER: Vigilanty L/U 4000 stall
DIFFERENTIAL: Moser 12 bolt w/ 3.73's
INTERCOOLER: Stock w/ big neck
THROTTLE BODY: stock
RJC POWER PLATE: no
INJECTORS: 95lb.
THERMOSTAT: 160
TURBOCHARGER: Prescision 70gtq
VALVE SPRINGS: 100#
MAF: none
DOWN PIPE: 3" ATR w/ racegate
EXHAUST: Dynomax ultra-flow
FUEL PUMP: Walboro 340
FUEL PRESSURE REGULATOR: billet adjustable
FUEL PRESSURE: 50 lbs.
ALCHOHOL INJECTION: yes, Razors kit (the best!)
PROPAIN INJECTION:no
NITROUS: no
AIR FILTER AND AIR INTAKE: K&N 9" cone w/ 4" intake
TIRE DESIGN, SIZE & AIR PRESSURE: 255/50 16 BFG Drag radial 2's
AIR BAG(s): none
SUSPENSION: Bilstein Gas
SCAN TOOL: Laptop
FUEL: Mobile 93
CHIP: FAST XFI
CHIP TIMING: 22 deg.
KNOCK RETARD: 1 deg. on the 3rd to O.D. shift
OXYGEN SENSOR VOLTAGE: 11.0 A/F ratio
EXHAUST GAS TEMPERATURE: n/a
TRACK ELEVATION: sea level
TEMPERATURE: 50 deg.
PEAK BOOST: 25 lbs.
BOOST AT LAUNCH: 4 lbs.
MILES ON THE CAR/ENGINE: 8000
Special Thanks to Anderson Performance auto, Julio of Alky Control, and CK Racing Trans.
Details of the run:
60' 1.655
330' 4.535
1/8 6.926
MPH 102.59
1000' 9.002
1/4 10.768
MPH 127.57
EMPTY WEIGHT: 3650
BLOCK: stock
CAM: Comp Cams
RJC POWER PLATE: no
INJECTORS: 95lb.
THERMOSTAT: 160
VALVE SPRINGS: 100#
MAF: none
NITROUS: no
AIR BAG(s): none
SCAN TOOL: Laptop
FUEL: Mobile 93
CHIP: FAST XFI
PEAK BOOST: 25 lbs.
