As much as I hate to do it, decided to sell my 87 T project before it's finished. Time to pay off some bills and get things ready to buy a house. Maybe after things settle back down I'll pick up another Buick. Anyway, here's the details:
1987 Buick Regal Turbo T hardtop.....code 15U Gray...WO2 blackout trim. Body is fairly straight and rust free. 174K miles on the chassis, but was owned by older lady, so wasn't abused. Original GA delivered car...have the original window sticker, bill of sale, owners manuals, receipts for work done over the years, maintenance records, etc. Body is in very good condition other than a few dings/small dents. Interior is in good condition, just sun faded from years of southern sunshine. Headliner is showing no signs of sagging, just needs a little cleaning. I'll list the new/installed parts below.
Installed:
Comp Eng 3 way adjustable front shocks
Tubular A-arms from Gbodyparts.com
Upper ball joints
Braided brake lines
Hurst Line Loc
Autometer Pro Comp Ultra Lite gauges:
*boost
*oil pressure
*water temp
Autometer 3 3/8" CF tach
Autometer mini shift lite w/signal box
Precision FMIC w/3" pipes
B&M trans cooler w/braided lines from factory lines to cooler
METCO billet LCAs
New parts waiting to be installed:
Moser 28 spline axles
Summit TA style rear cover
S10 wheel cylinders
CE 3 way adj rear shocks
F-body radiator w/dual Spal fans
GM posi rebuild kit
Caspers dual fan harness kit
Autometer PC Ultra Lite 2 5/8" fuel press gauge w/CF mounting cup
new power steering pump
Champion CNC aluminum A/C delete bracket
Engine Parts:
MPE sheetmetal plenum
Accufab 65mm TB
IAC angle boss
Fuel rail w/Motron 60# injectors
Turbo Tweak chip
Translator with LT1/SS maf
MSD 8.5mm wires
Turbo Saver/pre-filter kit from RedRegalT
Transmission is still in the car:
Pat's 10"/3200 l/u convertor
Billet input shaft
10 vane pump assy
PTS Extreme shift kit
I'm still waiting on final assembly of the engine, so if you want it with the car, it may be a few more weeks until it's done. Price will go up accordingly if you want the engine as well, but will be worth it. I was intent on having a 10 sec car when all was said and done, so very few used parts. I pulled the a/c compressor, condensor, lines off the car, but still have them and the factory bracket if interested. Heater box is still in place and worked quite well. As a roller, asking $7,500/OBRO. There's roughly $5K worth of parts with the car, so your getting a solid car for cheap. I'm sure I have forgotten a bunch of parts, so will update as I remember more of what all I have for it. If interested, shoot me an email at Slo86GN@yahoo.com or Slo86GN@gmail.com . Pics can be found at http://boosted6.com/Evil87GN/ . Car is located in SE Georgia.
Installed:
Upper ball joints
Braided brake lines
Hurst Line Loc
*boost
*oil pressure
*water temp
METCO billet LCAs
S10 wheel cylinders
GM posi rebuild kit
Engine Parts:
Accufab 65mm TB
IAC angle boss
Turbo Tweak chip
MSD 8.5mm wires
Billet input shaft
10 vane pump assy
