1KWIKSIX
- Sep 29, 2007
Have drained all the fluid out (luckily have a Hughes Deep Pan that has a drain plug) & removed all the botlts, but cannot budge the transmission pan. It is stuck!
I did have the aluminum pan powder coated , but the gasket sealing area was left untouched. Need your helpful suggestions. I've heard of people hammering in a thin metal putty knife, but I don't want to damage the transmission sealing surface which I'm afraid will happen.
Tried using a rubber mallet but no luck. Also tried prying (very gently) on an exposed section on a corner that I could access, but did not budge.
Not sure why it is not coming off. Transmission pan just installed earlier this summer by a local transmission shop who did the installation of the tranny & new convertor.
There is no signs of RTV being used, but I can't help but wonder if the shop did use something like this on the gasket.
I've also heard some people recommend spraying brake cleaner around the pan / gasket, but can't help thinking that this will not do much since the gasket/pan is stuck & there is no way for the fluid to enter between the two surfaces.
Looking for any help / suggestions.
thanks
dave
thanks
dave
