Anybody running a 15x10" wheel?
sheckyZ28
Id like to run 15x10 inch wheels on my GN. I was wondering who is running a wheel this size. Or if it is possible. Id like to run the Centerline telestars. I also need to know the backspacing. Will 5 inches BS work?
15x10 stock GN wheel
I sent out 2 of my stock 87 GN wheels to install new chrome outers into 10" with 3.75" rear back spacing.Using 295/50/15 tires.With the GNX rear fender flares.Tires look wide from the rear of car.It`s an eye-catcher. :cool:
Shecky,
I have the 15x10 Centerline Telstar 13's. The backspacing that I am running is 5 inches as my frame is notched in the rear. You should be able to get away with a 4 inch back spacing as I had a set of Cragar Street Stars that were 15x10 and rubbed the fender lip a smidge. If you roll the fender lip you will be A-OK
HTH
John Martin
1986 Buick T-type
10.91 @ 123.6
6.86 @ 100.7
15x10
I use to have 305/50/15 and it sticks out of fender.Looks awful and illegal.May get pull over by police with the tires sticking out.
I had a body shop bang up the fender lip 1" higher and paint the fender flares and installed them.Now I have 295/50/15 and it looks better with the 215/65/15 on the fronts.You can install them first.Maybe you might not need the flares if it don`t stick out
of the fender.
Telstar 15x10 184-135105547 Rear Spacing: 4.5''
Bolt Circle: 5 x 4.75'' It should fit fine make sure you have the airbags other wise on launch with slicks it might rub.
Mine didn't but some cars are off their body mounts slightly you know not centered on frame
