Anyone have the crank sensor pinout, need 87 vs 84
cool 84
Got hotair?
I've already put a post in the general tech but hopefully someone in here has an answer. I installed the 87 cranksensor today and connected it A to A, B to B, and so on. I have a feeling this is wrong and I need it to be perfect when I start the car. What I need is what each letter is (power, reference,ground) both on the 87 sensor and stock 84 plug at the harness.
crank sensor
You are correct it is wrong there is two wires that need to be switched. Trying to remember its been a while. I had the 87 ecm and ing module with the 84 crank sensor. I have the diagram with ecm pinpoints maybe that will help. if that will help email me direct and I can send a PDF file of that. My email address is dfisprnt@aol.com
