anyone running alky and nitrous?
davekusa
I got razors kit and is working good. I seem to finally have allot of the bugs out of the car. Is anyone running a dry nitrous nozzle and razors kit or a wet N2O nozzle with razors pump?
You need to run it wet. You only run dry shots when you have a way of adding additional fuel.
Isn't your kit "extra fuel"? I have been reading about this on another board, and I am really interested in what comes of using the alky kit for the wet side of a nitrous setup.
Yes, but still need to setup the non-nitrous stuff first. A pressure reading at the boost level being run would also assist in selecting the nitrous jet. So lets say at 20 PSI the pumps output is 100 PSI. So you figure your jetting at 100 PSI pressure. More than likely what will hapeen is when the button is pushed the boost will climb and deliver higher pressure on the alcohol, but thats not an issue too much as adding the extra nozzle for the nitrous should bring pressure down a tad.
When I ran it using the FAST, I used the correction to tell me which way to go with the nitrous fuel jetting. Meaning is the car runs zero correction when I spray alky+pump and it now needs to add lets say 5% correction with the nitrous, it needs a larger fuel jet to get it to zero correction.
