I've got a FAST computer controling my na 383 LT1. I recently slid an fairly aggressive solid roller in it and spent several days pulling my hair out trying to get throttle response, driveability and WOT tuned in speed density mode. I changed strategies and switched over to Alpha-N and the car seemed to really like it.
I've got a couple of questions that would really help me out in finding this thing's potential.
1. What AE tables (if any) are used in Alpha-N? I'm thinking just A/E FUEL VS. TPS RATE OF CHANGE. Is this true?
2. It seems to idle best about 1150rpm's with 30-32 degrees of timing, 38 total in by 3500. I've seen several other .gct files for na small blocks like this. Is this normal???? Everything I've ever read says 16-18 initial, 36-39 total. What gives?
3. I've got fairly respectable throttle response now, but I believe it should snap harder. What screen should I be looking at here? If its a 2D curve, can you give me an idea as to how it should plot out?
Thanks in advance. Here'e the combo:
383ci, 12:1
58mm tb, 1000cfm
ported LT4 intake
AFR 210's rr(285cfm @.700)
42# injectors
solid roller (312/325,.279/.286@.050,.679/.645, 108cl)
1.75 primaries on super comps
383ci, 12:1
58mm tb, 1000cfm
ported LT4 intake
42# injectors
