applied technologies RP354-DPA DOUBLEPUMPER
bpman1234
hi everyone here i took out my brand new old double pumper setup from at it has the 2 ac ep245 pumps .never used my ? is will this work on e85 right now i have 60 injecters and chip that i know i have to get sent in for my stock combo just a te44 wth the restalled to 2800 stock converter .i do have the gen2 and everything i need cardstyle mass with adapter even have a brandnew alky kit razers evrything is new .i know this pump set up is old thats why i want to know would they meet the demands of what i have for now .i know i should just get the 85s or 95s injecters but not sure wiyh these old new pumps .thanks in advance fellow turbo buick members .
60lb inj on e85 wont support much hP ...about 1/2 of what you could do on gas , about 380hp
the pumps can supply the injectors and then some and the pump coupler will be fine in e85 (no rubber hoses)
the pumps arent e85 rated (built way before it existed) but like the walbro 340 pumps they have been used with e85.
i personally wouldnt take the gamble on e85 without a specific rated pump , if you do be sure to watch the fuel pressure at WOT for if or when they start falling off
pacecarta thanks havent been here ina few days been working with my fourteenyear old son and his gopeds gas.but thanks .just wondering can i change out the pumps and if i could to what ?thanks again just have to bolt up the power steering res and the ic and rad and all fluids and theeeeeen turn key and fingers crossed.thanks again .
