Marineland Eclipse 3 Filtration and Illumination System if new $221.65
Fits 29, 37 gallon or 20 long aquariums. Eclipse 3 Filtration and Illumination System transforms an ordinary aquarium into an extraordinary aquarium. With its unique top-of-tank design, beauty, precision, and functionality, Eclipse requires virtually no assembly and installs in seconds. The convenient hinged panel opens to access a three-stage system of total filtration efficiency. All water is filtered through the high-performance Eclipse Filter Cartridge and then directed to the patented Bio-Wheel. The result is 100% water to media contact for excellent water quality and a healthier environment for your plants and fish. Enclosed in a clear, water-protected housing, the specially selected fluorescent daylight bulb is ideal for plant growth and ornamental fish color enhancement. Hinged for easy access, it lifts effortlessly for feeding, water changes, and general maintenance. Easy to install, easy to operate, the Eclipse System provides unlimited, unhindered access to the entire aquarium. And because all filtration media is inside the top mounted unit, the Eclipse has minimal rear space requirements for against-the-wall placement. Self priming pump restarts system automatically if power is interrupted. Removable pump module lifts out easily for cleaning and reinstalls in seconds.
20 gallon glass aquarium if new $30-$50
Aquaculture aquarium air pump if new $22.00
Matching black stand with storage space if new $100-$120
$200 for EVERYTHING including rocks & decorations pictured, new filter, and I am including a new in the box battery powered back up air pump for those pesky power outages durring hurricane season.
Pick up only. I am located in North Coral Springs
