Are Detroit Orange Head Gaskets OK to use on 109 block
Walt03
I have a set of Detroit Gasket 'orange' head gaskets that would fit a 4.1. They are larger than my bore at present which is .040 over at 3.840.
I really would like to use them on this 109 block if possible.
Could someone more knowledgeable than I point me in the right direction
on why I could or couldn't use them.
Your knowledge would really be appreciated.
How Much Boost Will You Run,if You Plan To Run 15 Lbs ,you Will Probably Get Away With It,,,,but Under Race Conditions ??????????
