Attention Chris
Lee Thompson
Rather than call you @ work, I will post here so you can read @ your convenience. In regard to my thinking your input shaft (size of oil feed hole) may have been part of my oil cooling and pressure problem. I installed a stock shaft and the problem is still there. I must be missing something in the pump. I am going to lay this pump aside and build a complete new pump and go that route. Thank you for your time--Lee
