Dec 28, 2008 #3 W WHEEZER Member Joined Dec 14, 2004 Messages 810 They will bounce all over the place at idle most times as the o2 sensor sends info to the ecm and the ecm is constantly correcting A/F etc.
Dec 28, 2008 #4 C chris mccord Member Joined Nov 25, 2007 Messages 339 Wideband or narrowband? A narrowband reading at idle and in closed loop would be moving all the time. You should look at cross counts to make sure it's moving enough. Wideband should be close to 14.7:1 at idle in closed loop.
