Bad MAF?
philosobrad
86 T-type acts goofy when going over bumps......tapped on MAF, and get the same condition. Is this normal??
No its not! Either the Maf is Flaky or the connection is bad but its Not Normal & should not happen. Check the connection but if your hitting it & it does it then probably the Guts of it are Toast! It is 20+ years old now. Upgrade to the newer style with a Gen 2 or go Mafless with a T-Pro from Full Throttle Speed. Mike will you out!
You rock!!
