Intercooler
- May 24, 2001
All mounted, wired,fittings, etc... and ready to go. This is a direct bolt in place aluminum radiator. The cooler is a B&M Racing Super-Cooler stacked plate. The fan is an 8" Perma-Cool that is wired into the main fan connector. All of it is done, just plug it in. The Radiator is a Be-Cool (about the best out there) with a new pressure release cap. The radiator alone is near $700 but it is the best! Has the oil cooler built in. This is about all you can do to cool all your fluids on the Buick. It did get a pinhole leak about the size of a ink pen tip on two of the rows toward the inside bottom from something that kicked into it but has been repaired and is good to go pressure tested.
I would prefer a local pickup but I will ship it.
$550 for the entire setup plus shipping. You can have the hoses too if you want as a bonus.
http://www.t6p.com/forums/attachment.php?attachmentid=7948
http://www.t6p.com/forums/attachment.php?attachmentid=7949
http://www.t6p.com/forums/attachment.php?attachmentid=7950
