JDSfastGN
- Jun 16, 2001
I was looking through my old manual and CKs new manual and looking at a real picture in CKs manual of the bearing that goes in the overdrive ring gear that mates to the planetaries, I am thinking i may have installed it upside down. My orginal manual shows it with what appears to be the "bigger" side (what most would assume is the top of the bearing) facing up with 3 notches equal distance apart around the bearing. But the picture in the CK manual shows it the other way. Is this something worth pulling the tranny and flipping around? Am I losing fluid/lube to the bearing having it this way? Its not something i want to do for sure but if it is going to cause a problem then I will pull it. The tranny already has 9,000 flawless miles on it. Thanks a lot
J.D.
J.D.
