ecmo92,
I use the TE44 on my daily driver. It will take you well into the 11's with the proper tune in, with your set up.
Old set up:
I have ran 1/8 mile times with the TE44, 009's, stock I/C big neck, 200/200 cam, Mod D5 converter and went 7.19. with 26 psi of boost. The 009's will lean out on a hard 1/4 mile pass.
My new set up is:
TE44, Comp 212/212, Power Plate, 009's, big neck I/C, Ported Irons SS big valves, T&D rockers, ported intake, 3" DP with Deltagate, 340 pump and hot wire, Modified D5 converter, Level 10 shif kit. etc. This combo is brutal on the street! I will soon add a SMC alky kit to go along with the 19 psi of boost I am running on pump gas.
IMO, the TE44 is the best street turbo period! I drive this car every day with good milage and great reliability. Not to mention when a Mustang comes along..... you get my point.
