your best bet would be to get a direct boost signal from the manifold, it is the strongest signal and you don't have to tap any other lines. What you do is remove the pipe plug on the front lower part of the manifold, (close to the drivers side, behind the fuel pressure regulator). Then replace it with a brass fitting of the same size. You can get the fitting in small hardware kits for boost/vacuum gauges, they usually contain boost line as well, and are available just about anywhere that sells gauges. I know sunpro and vdo have little kits like that. The fitting threads into the manifold, and the outer end has a compression fitting that you slide the boost line into and tighten it down. It's really pretty simple.
