BHJ harmonic balancer ?
JP87GN
Does anyone know for sure if the BHJ balancers are marked for 25deg ATDC? It appears there is a mark but I'm not sure if its a 25deg ATDC mark. It sure would make the cam sensor setting easy!
If the mark is 1.45" from the TDC mark then yes...mine wasn't marked...it is now though..:D
God I hope so, I've been using that mark for a while now to set my cam sensor. Car seems to run fine. HTH, Scott
BHJ V6 Harmonic Dampers Marked @ 25 Degrees ATDC
Hey everybody, Chris at BHJ Dynamics here. My first posting...
Yes, there is a timing mark at that location. It is a 1/2" long line, starting at the front edge of the inertia ring, approximately 1-3/8" *above* the TDC mark on the OD of the ring. (It will be *above* the TDC mark when looking at the damper from the driver's side.)
Great to be here. And let me know if anyone has tech questions I can answer for you about our dampers.
Chris @ BHJ
