TurboTA3.8
You wont keep up the pace
- May 24, 2001
TTA engine Fuel lines $60
tta oil cooler setup $80
tta/gn cam sensor $45
tta/gn 200 mile coil pack and module setup $100
tta motor mounts both sides right left engine and frame 1 frame mount need a small repair anyone with a drill and a welder can fix in 15min $150
a/c eliminator idler pulley $60
PTE polished 75mm doghouse and t body with ported lower intake and rjc plate to match $350
JW wheel flex plate $185
stage 2 balancer hub with crank trigger built in works with stock pulley dont know brand $175
TTA transmission oem x member complete with torque arm mount and trans mount $135
tta random technology torque arm $200
aeromotive pro series fuel pump with filter $550
buick engine assy bracket $50
paxton automotive afpr $75
stock tta fuel rail $20
fmic for tta needs a new discharge pipe made for a different then tta stock turbo easy fix at muffler shop to make a ic pipe $800
lakewood rear lca for tta $50
tta oem trans line one line has a small dent near rad atachment point but does not obstruct flow $75
tta radator and fans $150
tta oem full working dash cluster comple $600
tta oem complete engine wiring harness with relays $400
all prices do not include shipping
if you dont think a price is fair make a offer
george
george
