boost gauge install
T-TYME
Kind of a rookie question but this my first T/R! What is the best place to 'T' into for my aftermarket boost gauge? Any pics would but helpful-Thanks
I did mine within 10" of the intake mani. T'd into the line for the MAP sensor. I replaced the hard nylon lines with rubber/silicone to the MAP...mine were starting to crack.
T -ing the vacum line
I t'd into the vacum line just above the passenge valve cover near the fire wall. I bought a piece of copper line and snaked it through the fire wall above the steering column. The line went through easy since it's a hard line. I only had to use a small piece of rubber hose to connect the line to the T. The copper line cost about 2 dollars, but the good thing is it wont crack like a plastic line will over time. only downfall is the color is brigh instead of stock appearing, small price to pay to piece of mind. Just the way I did it , good luck..
I like to keep my stuff as "original" as possible and this certainly far from it so I am going to redo this but this will give you an idea
this is were I sent the line through the firewall
