Originally posted by BoostKillsStres
Just as Carl said, TL boost harness, 3 bar map sensor, the harness plugs into your MAT wire along with the TPS for power to the MAP. Then use a mitty pump or some regulated air pressure source and a good known gauge for accuracy and start adding pressure to the MAP sensor while building a table of MAT values reported in DS then after a run just reference your table to see what boost you were running based on the MAT DS reported.
Now this won't account for atmospheric condition changes like the TL setup will as it has a zeroing feature before you start the car. So you'd have to look at the MAT reading in DS before you started the car to see which way your table would be skewed for correct boost but we're not talking about a wole lot of change.
HTH
