Brake Light coming on.
ACLR8R
As of late my brake light has been coming on when I push on the brake. If I put the brake on really slowley and gradually it wont but when driving normally it does. Braking is normal though. Is this an indication of the powermaster on the way out or what? Any one have this problem?
First make sure you have the correct grey pressure switch. If yes then it sounds like an accumulator ball. I had the exact problem. Changed the ball and everybody was happy.
Same thing here. Just changed the accumaltor yesterday and everythings ok. Accumaulator was 149 from kirbans.
the pressure switch is behind the fluid reservoir on top of the powermaster. Just look for the wires running to the powermaster and the switch is right there.
