Spool'n Fool
- May 3, 2006
My brake light started coming on for a moment, when I pressed the brake pedal. Like a good dooby, I put more fluid in the res.. Then the cap didn't seal right, so the fluid went all over. The I resealed and bled the brakes and after 5 pumps with the car off, the res would overflow on the pass res side and spew again.
I then tried bleeding with the engine running, (only fronts)... no big changes..
When running the engine, the res fluid stabilized (lowered toward 1/2 way mark)...
Soooo, what the heck is going on and how does one bleed this set up differently than the typical GM's? Oh yeah, the light is doing the same thing...On for a longer moment now when hitting the pedal with car running. I need to rebleed...
Help!! I need to drive it..
