I looked through the Powermaster tech troubleshooting page but didn't find my exact problem.
I've had my Buick for a few months now and have never had brake problems until a few weeks back. I noticed that it was leaking a bit somewhere on the brake cylinder so I decided to open the top and peak inside to see the fluid level. Now I just peaked in there and it looked good so I put the top back on. Next time I drove it a few stops away from my apartment I started losing power in my brakes. I would push on the brake but it was like it hit a "block" halfway down so it was just barely braking and I couldn't press further. I kept pressure on it and it eventually started going back down. I did this a few more times to "pump" it up hopefully. After that it was fine for the rest of the drive.
It's always like that now. I have to "pump" the brakes a few times to make sure it has good stopping power before I take off in it. It still has that "block" on it to where if I keep pressure on it it will eventually give way and go further down. I have to keep doing this before I take off. But once I leave the car never has braking issues after that, until I shut it off and let it sit a few days. The car usually sits for days at a time. I've always pulled the tops off other master cylinders and never had a problem, I guess these powermasters are little bit different.
So I know pulling the top off the master cylinder had to cause this because it was fine before? What can I do?
