Guys,
Just recently replaced all my flexiable brake lines, calipers, rotors, pads, resevoir seals and new fluid.
Bleed the system all four corners, and what is happening is I will take the car out and first it seems to stop fine for a little, but as I get on it more and warm the rotors up the brake pedal starts to feel hard and makes it tuff to stop.
If I let the car sit and try again the same thing occurs. After 10 pump ignition off, then when I turn the ignition on the mortor will run for like 12-14 seconds and then stop and not come on anymore, unless off and re-pump again. Can my master unit seals be going, and the I know the accumalator is like 12 yrs old but very little driving since the car is a sleeper most of the time.
Any ideas on what the problem may be, or should I try another set of pads with better stopping power, just seemed that decent semi pads would loose stopping power after 5 min of driving!
