Broken passenger side motor mount
1BAD_GN
1BAD_GN
Can a bad motor mount cause knock retard to show up on scan master? Running 18lbs with stock turbo/alky, alky TT chip.
yep. It sure can.
Normally it's the drivers side that makes all the noise but at $10 each, go ahead and replace them both while you're there.
yep. It sure can.
Thanks Earl!! I'm sure they stock them at the local stores
and whatever you do.... MAKE sure you don't mix up the left and the right!!!!
There's only a slight difference in height for the motor mount bolt but if you get them backwards you will NOT get the PS bolt to pass through!
don't ask me how I know!! :D
