high speed fan
Hi,
I would replace the switch. It ain't there unless it has a function, trust me. Key on,ground the connector wire. That should turn on the high speed fan winding. If not, high speed relay is probably bad, which is a common occurance. Water gets into it, adios relay. It's on the left fender, large relay.Good luck!
